Adm2587 transmit error
Hi Everyone!
I would like to ask for a help about adm2587 interface and pull-down/pull-up resistors on the pins.
My interface is viewable on the attachment. Now the receiver is working, but the transmit does not send data, only 0.
What is the problem? I connect A and Y to A+,  B and Z to B- to my RS485 USB CONVERTER.
Parents
  • Hi RAnslow,
    The second schematic is correct. I use 10K resistors to pull up / down my PIC pins. This configuration with max485 or sn75176 works good.
    "What is the purpose of R24 and R26. Are these current limiting (protection) resistors ?" - Yes.
    R4 and R7 is a biasing resistors.
    "Which configuration are you using? " All jumpers are off.
    "Which configuration is working for you?" None.
    Thanks for your answer.
    Any idea?
Reply
  • Hi RAnslow,
    Any idea?
Children
No Data
