Is it possible to make an Optically isolated plus a Loop Power HART-RS232 Modem?
I came across a loop powered HART modem
http://www.analog.com/static/imported-files/circuit_notes/CN0267.pdf
Also I came across An Isolated HART modem
http://www.analog.com/en/circuits-from-the-lab/CN0321/vc.html
Is it possible to combine the two of them so that we do not Need external Power , also the communication remains isolated?
Parents
    on Oct 4, 2013 11:29 PM
    Hi patelvijay12007,
    In relation to the interface between the loop and the HART modem figure 27 of the AD5700/AD5700-1 datasheet may be of use to you (there is additional information on this circuit in the datasheet as well):
    In terms of the HART software stack, CN0267 only implements command 0 which is a simple command that confirms the presence of working HART device. If you do not have a HART stack, to develop or purchase a full HART stack you'd need to work through the HART Communication Foundation where a list of HART stack providers is also available.
    In terms of RS232 transciever, the ADM3101E or ADM101E may be a good option for your application.
    Derrick
Reply
    Hi patelvijay12007,
    Derrick
Children
No Data
