Dear Analog Devices Support Team,
I am currently evaluating the ADM3066E and would appreciate your guidance regarding operation outside the specified supply voltage range.
According to the datasheet, the recommended operating supply voltage starts at 3.0 V. We would like to understand the expected behavior of the device when powered slightly below this limit, for example in the range of 2.7 V to 3.0 V.
Could you please clarify the following:
- Is the ADM3066E expected to continue operating correctly when supplied with VCC = 2.7 V to 3.0 V?
- Are there any known functional limitations or failure modes that may occur in this voltage range?
- Could any key parameters degrade or change, such as communication data rate, receiver sensitivity, driver output levels, timing characteristics, or EMC performance?
- Has Analog Devices performed any characterization or validation testing of the ADM3066E below the recommended minimum supply voltage?
Any information regarding expected performance, reliability, or characterization data in this operating region would be greatly appreciated.
Thank you for your assistance.
David.
Edit Notes
added tag (datasheet/spec)[edited by: David2026 at 12:20 PM (GMT -4) on 11 Jun 2026]
