MAX7360 Pin Description and Pin Configuration Mismatch
Category: Datasheet/Specs
Product Number: MAX7360
Hi everyone,
I’m currently creating a schematic symbol for the MAX7360EWX+ and noticed a mismatch in the pin numbering information in the datasheet.
However, in the Pin Description table, the numbering seems different, which makes it unclear which reference should be followed when defining the symbol pins. Because of this discrepancy, I’m unsure which source should be considered correct when creating the symbol:
  • The Pin Configuration diagram, or
  • The Pin Description table
Has anyone worked with this device before or encountered the same issue? Which reference did you follow when building your library component?
Any guidance would be appreciated.
Thanks!
Datasheet: MAX7360 I2C-Interfaced Key-Switch Controller and LED Driver/GPIOs with Integrated ESD Protection
Edit Notes
Added the IC name in the title
[edited by: aravind14842 at 4:05 AM (GMT -4) on 10 Mar 2026]
