MAX22664C
Product Number: MAX22664
Dear Engineer,
We would like to use the MAX22664C for isolation purposes. In the datasheet, there is a mention of the default state of the component, described as follows:
"The MAX2266_B/C feature default-high outputs. The default is the state the output assumes when the input is not powered or if the input is open-circuit. The MAX22663-MAX22666 has two supply inputs (VDDA and VDDB) that independently set the logic levels on either side of the device."
I understand that in the case of no power from VDDA, the output value will be high if VDDB is present. However, I wanted to clarify what is actually meant by "open circuit." Does this mean that if the input is connected but not driven (i.e., floating or in a high-impedance state), it assumes the default value (high)? Or does it only refer to the case where no input is connected to the component at all (open input)?
Diallo
