Alternate MPN for MAX233ACWP+G36
The user inquires about an equivalent replacement for the obsolete MAX233ACWP+G36 with the same footprint and specifications. The recommended solution is to redesign using the MAX232 or MAX232A, which requires adding 4 separate exterior capacitors for the charge pumps. No direct pin-to-pin replacement is available.
Category: Datasheet/Specs
Product Number: MAX233ACWP+G36, MAX233A
Since MAX233ACWP+G36 is now obsolete, could you please recommend an equivalent alternate MPN with the same footprint and specifications?
Also, could you please advise the key differences between the alternate part and MAX233ACWP+G36?
Thank you!
