MAX22191: Common vs Separate Field-Side Ground for 4 Digital Inputs
The user asks if the GND pins of four MAX22191 devices should be tied to a common field ground or kept separate for a digital input module. The final answer states that if channel-to-channel isolation is required, each MAX22191 GND should be separate. If the inputs share a common field ground, the GND pins can be connected together.
Product Number: MAX22191
I am designing an industrial system with four 24-V digital inputs (source/sink type), using one MAX22191 per input.
On the field side, should the GND pins of all MAX22191 devices be tied to a common sensor/field ground, or should each MAX22191 have a separate, individual field-side ground?
All inputs are part of the same digital input module, and the goal is correct operation while maintaining proper isolation .
Thank You
