Hi, I have been having strange problem with MAX13487 active buffer design, which I now realise may be the echo detailed here
This note says When the RE pin is pulled up, the data received at the DI pin can be seen at the RO pin.
However, in a second post here it explaining how to solve it, it says I must pull up the RE Pin, which seems conflicting with the first post, which suggest having RE pulled up causes the issue in the first place.
Could you explain which it is?
Thankyou.
