I use ADN4654 could translate 400MHz CLK from (port-in) to (port-out),but could not translate 96MHz CLK
The user encountered issues with the ADN4654 isolator failing to translate 96 MHz MIPI CLK signals, while 400 MHz signals worked fine. The problem was resolved by moving the termination resistors closer to the FPGA and confirming the MIPI LP signal voltage swing was within the ADN4654's input threshold range. For MIPI data isolation above 800 Mbps, the user seeks a detailed hardware design solution based on Figure 5 from the provided Analog Devices article.
Product Number: ADN4654
Dear,
ADN4654 datasheet promises any data rate up to1.1Gbps, I could  translate 400MHz CLK , but  I am unable to translate 96MHz CLK.
(pic from datasheet)
1. 96MHz CLK are currently isolated using ADN4654
1
) Waveform before isolation(INPUT)
2) Waveform after isolation(OUTPUT)
You can see a bad wave signal.
2. The waveform of 400MHz has been tested before, which is OK.
Please refer to our schematic,and help us to confirm the minimum speed supported by the ADN4654.
Thank you.
Edit Notes
change a pic
[edited by: Hardwk at 1:05 PM (GMT -4) on 1 May 2025]
    Thanks for reaching out,
    In order to help you, I need the following information:
    Can you provide the full output signal chain?
    Can you also provide the output layout?
    Where and how are you sensing the input and output voltage waveforms?
    Kind Regards,
    Riccardo
    1.PCB Layout ( TOP LAYER)
    2.SYS BLOCK
    3.Test POINT( Green is 100 ohm , and oscilloscope test on resistance)
    Thank you .
    The first thing that catches my attention is that termination resistors are placed right at the output of the isolated buffer instead of being placed at the end of the transmission line (so close to the receiver of the FPGA) to minimize reflections. What is the lenght of the traces between the isolator and the FPGA?
    It seems there are series components at the input of the isolator besides the termination resistor. Is that a common mode choke? what is the part number? what is feeding the signal to the isolated buffer?
    Are there any other components in the signal chain? like ESD/TVS diodes? at first sight, it seems the problem might be some clamping happening at the output.
    Can you share what is the protocol, part number and port configuration of the FPGAs you are using?
    Can you make sure to check the following requirements?
    Kind Regards,
    Riccardo
    --> now ,we change the place of terminate resistance.
    before:
    the terminate resistance(100 ohm) near adn4654
    after:
    the terminate resistance(100 ohm) near FPGA.
    the mipi clk(INPUT) translate lvds clk(OUTPUT) ,the wave is ok .
    --> yes, there is a choke(part numbe:DLW21SZ900HQ2L),it seems to have no effect to translate the signal.
    --> no ESD/TVS diodes
    --> Xilinx AU serier FPGA , LVDS protocol
    now another problems:
    Now adn4654 translates mipi clk is ok,but there is something wrong with mipi data to translate ,some adn4654 failed to translate the mipi data.
    mipi data(INPUT):
    lvds data(OUTPUT),translate OK
    lvds data(OUTPUT),translate failed
    we have 2 pcb boards, every pcb board have 2 chips (adn4654),
    board 1 :
    #1 adn4654  translate OK,#2 adn4654 translate failed.
    board 2 :
    #1 adn4654 translate  failed,#2 adn4654  translate OK.
    board 2 :
    we replace #1 adn4654 with  a new chips ,it  tranlates OK.
    Whether there will be individual performance differences in the chip(ADN4654), the mipi data contains a single-ended LP signal, I don't know if there is an impact on the processing mechanism of the ADN4654, The LP signal is much longer than the HS on the whole signal, and whether it also affects the ADN4654 internal state machine switching
    Thank you
    I didn't fully understand the signal chain yet. Is there an FPGA also at the input? You said the protocol is LVDS, is it LVDS at the output and MIPI at the input?
    The LVDS isolators serve as limited re-drivers, meaning that the output swing is fixed and doesn't not depend on the input one (also the input thresholds are symmetric with respect to differential zero). If the input voltage swing changes from MIPI HS (High Speed Signalling Mode) to LP (Low Power Signalling Mode), it won't be able to change the output accordingly. In order to isolate the MIPI protocol, you need to use MIPI to LVDS bridge ICs (e.g. MC90201/2) or FPGA IPs
    Kind Regards,
    Riccardo
    Please see the pic ,
    ADN4654 get the input data (mipi-data/mipi-clk )from the cmos sensor(CSI),
    and output data ( lvds-data/lvds-clk) to the FPGA,
    the mipi-data of  the cmos sensor (pic#A)
    some adn4654 could translate the right  lvds-data(pic#B),some could not (pic #C),
    why for these differences, in generally, the differences between chips are very small.
    Thank you.
    You need to make sure the input voltage is within the specs of the isolator. The isolator minimum input voltage swing depends on the input thresholds:
    The MIPI HS has a quite low minimum voltage swing (140mV --> +-70mV around the common mode voltage).
    The maximum and minimum thresholds specified in the datasheet are guaranteed for each IC and if the input voltage swing satisfy the minimum voltage swing requirement, the isolator is able to detect the signal. I guess the output voltage swing of the MIPI Image sensor might get too low sometimes and fall below the minimum acceptable for the isolated buffer.
    I would recommend to use a bridge IC or an FPGA inbetween the sensor and the isolator.
    Kind Regards,
    Riccardo
    Thank you for your help, we have now identified the cause of the problem.
    We checked the MIPI signals output by the CMOS Sensor again and confirmed that VID of the MIPI LP is between -100mV and 100mV.
    From the truth table of ADN4654, it is in an indeterminate state at this LP time.
    So, if we do not use other ICs (such as MIPI to LVDS conversion chip), how can we make ADN4654 output a fixed value (either a fixed high level or low level) when the input signal is between -100mV and 100mV(VID of MIPI LP  )?
    Thank you.
    You can use an external fail safe network to prevent the output from switching randomly when the input is in-between the indeterminate state. The ADN4655 and ADN4656 have this fail safe mechanism integrated, which guarantees an output logic high when the input differential voltage is in that range.
    Here a reference for the fail safe network working principle and design steps: https://www.analog.com/en/resources/technical-articles/understanding-lvds-failsafe-circuits.html
    Did you verify the swing of the MIPI HS, what is that? if you use a fail safe network you will introduce a differential offset which is equal to the max threshold (100mV). You need to make sure to have enough input voltage swing margin to implement that.
    The fail safe will guarantee a fixed output state when the input is in indeterminate region but it won't help to pass through LP signals.
    Kind Regards,
    Riccardo
    Thank you for your reply.
    According to the link you provided, we use figure 3 to solve the problem of LP( mipi isolation transmission), and the LP is OK after isolation.
    As you can see from the article, this figure 3  is suitable for signal transmission below 800Mbps.
    now, we still have the demand for mipi transmission isolation above 800Mbps, and we want to use  figure 5.
    Is there a detailed design hardware solution design (about  figure 5) , we would like to try it.
    Thank you.
