I would like to use this IC, but I will not be using the negative power supply (V-, AV-).
Will it be okay to leave V- and AV- floating?
I will be using 5V and 12V.
(LTM2883IY-5I#PBF)
Best Regards,
Koji
September Monthly Blog Quiz! Read the blog, take the quiz, and you could win a gift card
Quiz: How Well Do You Know Adaptive Power Switching?
Is your I/O module overheating? The AD74416H's Adaptive Power Switching (APS) can cut heat dissipation by up to 40% — but how well do you really understand how it works?
Read the blog first: Cooling
LTM2883
Production
The LTM2883 is a complete galvanic 6-channel digital μModule® (micromodule) isolator. No external components are required. A single 3.3V or 5V supply...
Datasheet
LTM2883 on Analog.com
(LTM2883IY-5I#PBF)
Best Regards,
Koji
Hi Koji,
If you're not using the negative power supply it is OK and in fact preferred to leave the pins V- and AV- open / floating.
Eric
Hi Eric
Thank you for your quick response.
I understood.
Best Regards,
Koji
