Hi!
I'm testing the MAX14937 bidirectional digital isolator and when I drive the side A with a square wave signal the transitions looks like the following image (ch2, green -> I/OA1 [pin5] ach1, yellow -> I/OB1 [pin 12]):
As you can see, the input response (ch2) oscillates quite a lot, reaching 4 V at most, before going high (3.3 V). I think it is because the rise time of the input (ch2) is too short, and it is necessary, through an RC filter, to slow down the input signal. Is this correct or am I doing something wrong?
This response does not appear when driving in the opposite direction, from B to A:
I have tested the response of the IC with two signal ramps at different slopes (1.2 v/us and 4V/us) and the response of the slow one is smoother, so I think it is necessary to slow down the signal.
Thank you very much in advance.
