The MAX3471 already has integrated fail safe protection will this cause an issue with a master card with external bias pull up & down resistors?
KCC Quizzes AQQ303 about the radius of a circle
1. Quote of the month: "When I die, I want to die like my grandfather who died peacefully in his sleep. Not screaming like all the passengers in his car" - Will Rogers
2. Quiz AQQ304 about finding the radius of a circle
Good luck, and try to be
August Monthly Blog Quiz! Read the blog, take the quiz, and you could win a gift card
Important: Read the blog first . The quiz questions are all based on the content of the blog:
Stay in the loop and win! Read the blog Current Output Driving Industrial Loops , then take our quick five-question quiz for a chance to win a gift card
MAX3471
Production
The MAX3471 half-duplex transceiver is intended for lithium battery-powered RS-485/RS-422 applications. It draws only 1.6µA (typical) supply current from...
Datasheet
MAX3471 on Analog.com
The MAX3471 does not require external pull-up or pull-down resistors for fail safe operation to drive the RO output to a known state. Note that the MAX3471 is designed for very low data rate battery powered systems and its drive capability is limited based on operating voltage.
