KCC's Quizzes AQQ306 about a fish stick challenge
1. First the quote of the month: " I am so clever that sometimes I don't understand a single word of what I am saying" - Oscar Wilde
2. New quiz AQQ306 about a fish stick challenge:
Here below is a pseudo fish diagram swimming to the right.
Question
November Monthly Blog Quiz! Read the blog, take the quiz, and you could win a gift card
Ever wonder how EMC limits came to be and why they matter? Dive into the interesting bits of EMC limits and levels, then test your knowledge with EMC: The Interesting Bits Quiz.
Read the blog first: EMC Limits and Levels Explained: Well, the Interesting
ADM3057E
Recommended for New Designs
The ADM3055E/ADM3057E are 5kV rms and 3kV rms isolated controller
area network (CAN) physical layer transceivers with integrated
isolated dc-to-dc converters...
Datasheet
ADM3057E on Analog.com
I had made a design with ADM3057EBRWZ transceivers. There was a overcurrent failure on the 5V line of on my PCB.
In my design 5V was used as VCC pin (pin no 3) of ADM3057EBRWZ IC. After the overcurrent failure I'm trying to find the root cause and what ICs have been affected by the failure.
I checked the impedance from B6, B7 and B8 pins to GND pins (B1 to B5) and I'm observing the following:
We have 7 such ADM3057E ICs on our PCB. I have listed the min and max value from my observation:
Impedance measurement between Impedance (in ohms)
pin 3 (VCC) and pin 1 (GND1) 38 ohms - 76.6 ohms
pin 16 (VISOIN ) and pin 11 (GND2) 37kohms - 52.8 kohms
I wanted a know if these readings are alright or has the IC been damaged.
Thank you,
Abhishek
I measured a fresh ADM3057 and observed:
I think that the isolated-side of your parts are likely OK; however, the non-isolated sides likely have been damaged.
Eric
