ADM3260: SDA side 2 stays high while SDA side 1 goes low
Product Number: ADM3260
Hi!
I am using an ADM3260ARSZ. On side 2 there is a STM32F439GV (main). On side 1 there is a BQ3050 (device). I am trying to initiate a communication between those two. In the following picture you see the main(SCL: Blue + SDA: Red) transmitting an I2C request to the device (SCL: Green + SDA: Yellow). As you can see, the mainsends the 8 address bits and the deviceacknowledge the request by pulling sda (yellow) low. Nevertheless the ADM3260 ignores the acknowledge and the main's sda stay high (red).
For me it looks like the ADM3260 only checks the SDA input on the SCL's falling edge!? As you can see after the next SCL falling edge, when the SDA is indeed pulled low.
How could this be? The BQ3050 can not acknowledge faster. And probably many other I2C components are not fast enough either. How can I solve this problem?
  • Hi Julian,
       I suspect that the SDA voltage during the ACK period on the ADM3260 side 1/device SDA node is low, but not low enough for the ADM3260 to recognize it and so the ADM3260 is keeping the side 2 SDA high.  The device is pulling SDA1 low fast enough with plenty of time remaining for the ADM3260 to detect and drive the other side low before the rising edge of the SCL.  Also, I'm pretty sure that the reason the red SDA falls with the clock's falling edge is that the controller having (incorrectly) observed a NACK then pulls SDA low in preparation for generating the Stop condition.
       What are the low level voltages at the pins of the ADM3260?
    Eric
  • Hey Eric,
    Thanks for your reply!
    I measured the following voltages of the SDA lines. The positions are marked in the picture.
    Where 1 2 3 4 5 (max) 6 7 8
    Side 2 / Main / Red 3.30 V 0.15 V 3.30 V 0.15 V 3.30 V 3.30 V 0.15 V 3.30 V
    Side 1 / Device / Yellow 3.28 V 0.48 V 3.29 V 0.48 V 3.11 V 0.41 V 0.46 V 3.29 V
    1. For my understanding: The ADM3260 "ignores" the I2C protocol, correct? So It just transmits the raw signal without interpreting the signal. So the ADM3260 does not know about ACK, address, etc.
    2. The SDA voltage of the device is lower during the ACK phase than elsewhere as you can see in my table above (0.41 <-> 0.46 V). I watched this tutorial video about how Analog's I2C isolator works. So maybe you are right, the voltage at 6 needs to be lower, so the isolator redirects the signal from side 1 to 2.
    But what is the needed voltage? As I understand the datasheet, the voltage at 6 needs to be 50 mV lower than measured at 7? (-> Input/Output Logic Low Level Difference). I will try to increase the pullups a bit more, so the difference might increase enough.
    Best regards
    Julian
  • Indeed, increasing the pullups to 3.3k did the trick...
