Question about VDDB pin of ADG3123
Category: Datasheet/Specs
Product Number: ADG3123
This is Kwonjoon Lee from South Korea.
I would like to ask about the VDDB pin of the ADG3123.
(Detailed Question)
1. We would like to use only first 6 channels (A1-A6 and Y1-Y6), and we will not utilize other 2 channels (A7-A8 and Y7-Y8).
    In this case, could we apply 14V and 0V to the VDDA pin and the VDDB pin, respectively?
Kwonjoon Lee
  • Hi  ,
    This setup is not possible as this will violate the device's absolute maximum ratings and may cause permanent damage.
    The product datasheet mentions that the VDDA ≤ VDDB. The voltage between VDDB to VSS and VDDB to GND is 10.8 V minimum. Tying the VDDB to GND breaks the condition.
    I suggest tying the VDDB to the VDDA and being mindful of the power supply sequence. It is a good practice to power up the VDDA and VSS before applying signals to its inputs (VDDA and A1 to A8).
    Christian
