MAX14850 intermittent arbitration error
Category: Datasheet/Specs
Product Number: MAX14850
We're using the MAX14850 to isolate an I2C interface and are getting intermittent bus arbitration errors reported by the controller. The interface is a single controller connected to the A-side, and a single target connected to the B-side, running at 400kHz. When the interface is working, we have good waveforms, and can see the controller-side (i.e., I/OAs) transitioning low to high where it goes 0V --> 0.7V (I/OA logic-low voltage) --> 3.3V (pull-up), which is expected (right?). But since the error is occurring intermittently, it's hard to get a waveform of the error behavior.
One idea is that the I/OA pin releasing to 0.7V first for a little bit before fully releasing to be pulled up to 3.3V could be getting interpreted by the controller as an extended logic low on the SDA line sometimes, therefore resulting in the arbitration error. Is there a spec for how long the MAX14850 I/OAs will regulate the logic-low voltage for?
Alternatively, do you have any other ideas for why this could be happening?
Thanks!
  • Your understanding is correct that when I/OAx transitions from being driven low (~0) to high (while I/OBx is not externally driven low), the rising transition of I/OAx will be from ~0V to VOL(I/OAx) = ~0.7V and then to Vdd.  This plateau occurs because the I/OBx side is initially being driven low until the low->high transition is indicated to the I/OBx driver to release I/OBx.  Once this happens, I/OBx needs to rise enough that I/OBx is recognized as now being high so that the I/OAx driver can be turned off and the I/OAx bus can then rise to Vcc.
    This plateau will be the sum of the forward and reverse propagation delays + the time for the I/OBx to rise from the output low voltage driven by the I/OBx driver to the input high voltage (~0.7Vccb)
    In terms of if this is causing the issues with the communication, it may or may not be.
    First, what is the VIL for the controller?
    next, except for the ACK bit, does data only flow from the controller to the target?
    If the data is flowing only from the controller to the target (except for the ACK bit) and the VIH is close to the 0.7V this potential could point to the issue.
    If, however, the target sends read data back successfully, then presumably this VOL of 0.7 is sufficient and there may be other items happening in the system which need to be investigated.
    Eric
  • Hi Eric,
    We ended up white-wiring the MAX14850 to connect I/OB to the controller and I/OA to the target, and still had the intermittent arbitration error, so it's looking like it's not due to the 0.7V level.
    This is a bit of a long shot and moving away from the MAX14850 specifically, but I was wondering if maybe you'd know how to handle this:
    Our latest discussion has been whether the rise time might be just slightly too long. A caveat about the interface is that the controller and target endpoints are 1.8V logic, not 3.3V. Both the controller and target are COTS cards that have a level-shifting bus switch (https://assets.nexperia.com/documents/data-sheet/74CBTLVD3245.pdf) with a 10k pull up to 1.8V. The backplane has 10k pull ups to 3.3V added on both sides of the MAX14850. I'm trying to verify whether the pull-ups were sized correctly, so when I'm calculating Rpmax, would the bus capacitance take into account the entirety of the isolator to the FPGA endpoint, or separate into "sections" the 3.3V section (between isolator and bus switch) from the 1.8V section (between bus switch and FPGA) to calculate Rpmax for each logic level "section" separately?
    Thanks anyways for your help!
    Gillian
  • If your issue is still present after jumpering across the MAX14850, then its likely that the MAX14850 is not responsible for your problem.
    How you partition the total bus capacitance for your Rpmax calculation will depend on the details of the level-shifting bus buffer's internal characteristics.
    Since this particular buffer isn't an Analog Devices part, I can't help you with those details in this forum.  You'll need to follow up with that part's manufacturer for support.
    Eric
