Positive(TTL) to Negative voltage Level shifters(0 & -8V)
Product Number: NA
Hello, I am looking for a Level shifter which can translate 5V TTL pulse to a 0 to -8V swing. We are using this signal to control  an RF Switch whose control lines work with 0/-8V signal. Rise time(7nsecs) and Switching time(20nsecs) is critical for this application and cannot be compromised. Appreciate, if you could please recommend a suitable device or a design that can meet this requirement. Thanks
Hello, I am looking for a Level shifter which can translate 5V TTL pulse to a 0 to -8V swing. We are using this signal to control an RF Switch whose control lines work with 0/-8V signal. Rise time(7nsecs) and Switching time(20nsecs) is critical for this application and cannot be compromised. Appreciate, if you could please recommend a suitable device or a design that can meet this requirement. Can we use MAX913 to achieve this? Please advise.Thanks
[edited by: Rabin at 3:59 PM (GMT -4) on 1 May 2024]
    There are no standard data isolators in the portfolio that have TTL logic input levels. The application would have to adapt to CMOS levels.
    It is certainly possible to use an isolator to shift voltage domain. There is not a device that can be supplied directly with 8V though. The prop delay of the ADuM341E is less than 10ns. That might leave enough timing budget to put some shifters in series.... but isolation may not be the best solution if galvanic isolation isn't actually needed.
    Jason
  • Hello Jason. Thank you very much for your reply. Is there any application diagram/note that discusses such implementation based on ADuM341E? That would really be a big help. Regards
