Ask questions about ADM3055E
The user asked if the ADM3055E CAN transceiver's transmission distance varies with different data rates and how to calculate it, as well as how to test CAN bus signal quality. The final answer explains that faster data rates generally require shorter distances due to round trip delays, which include transceiver and controller propagation delays and cable delays. The sample point in the CAN controller must be set to accommodate these delays. For signal quality testing, generating an eye-diagram is recommended.
Product Number: ADM3055E
1.ADM3055E is a CAN transceiver, If using different data rate, can it have different transmission distance? If yes, how to calculate its actual  transmission distance with rated data rate?
2.If I want to test can bus signal quality, how to do it correctly?
Thanks!
  • ADI North America will be on winter shutdown starting December 25, 2023; perhaps another community member can assist you until our return on January 8, 2024.
  • Hello Jerry,
    1. There is a relationship between the CAN Bus transmission distance and data rates with faster data rates generally requiring shorter distances; however, the calculation of the maximum bus length at a specified date rate depends on more factors than just the data rate and cable length / propagation delay.  It includes the settings / performance of the CAN controller which determine when the bus is sampled.   Usually, this sample point is set as a quantized fraction of the bit time and may be adjusted as part of the system commissioning.
    CAN uses an arbitration scheme where two or more nodes determine who will control the bus by all writing data at the same time and confirming that the bus state is as they wrote.  When a node reads back something different, then it has lost the arbitration, disconnects and waits for the bus to become idle before trying again.  This is possible because the recessive state ("1") is high-impedance and the dominant state ("0") is driven and so a dominant bit will overwrite a recessive bit.  This means that the node needs to wait for a full round trip before sampling the bus.
    The total round trip delay in the bus is twice the sum of the transceiver propagation delay, controller propagation delay and cable delay and this needs to be smaller than the time of the bit sample point which is some fraction of the total bit time which is equivalent to the data rate.
    This is discussed in the technical article Optimizing CAN Node Bit Timing to Accommodate Digital Isolator Propagation Delays.
    Note that depending on the network wiring quality, there may be some additional delays factored in to allow reflections and ringing to decay before the sampling point.
    2. Generating an eye-diagram would be a common analysis method for analyzing the signal quality.  Searching on "CAN bus eye diagram" returns a good number of different sources and videos discussing this method.
    Eric
