For a high current battery charging application, we need to parallel two SiC Mosfets for each of H-bridge switches. We are using ADUM4135 as isolated H-bridge drivers.
How can we drive the parallel combination with ADUM4135?
This gate driver requires to directly sense the Gate pin of the Mosfet. However, as the general rule, we should not short the Mosfet Gate terminals.
Is there any way out? Can you please suggest a schematic?
Or, we should drive the Mosfets by dedicated ADUM4135 ICs? Can we guaranty the simultaneous turn-on, turn-off in that case?
Thank you.
