Hi
In ADM3202 datasheet, Short-Circuit specification is below.
Does "Continuous meaning" include "IC don't breakdown in Short-Circuit "
Best regards
Thank you very much.
September Monthly Blog Quiz! Read the blog, take the quiz, and you could win a gift card
Quiz: How Well Do You Know Adaptive Power Switching?
Is your I/O module overheating? The AD74416H's Adaptive Power Switching (APS) can cut heat dissipation by up to 40% — but how well do you really understand how it works?
Read the blog first: Cooling
ADM3202
Production
The ADM3202 / ADM3222 / ADM1385 are high speed, 2-channel RS232/V.28 interface devices which operate from a single +3.3 V power supply. Low power consumption...
Datasheet
ADM3202 on Analog.com
Hi
Best regards
Continuous Short-Circuit at ABS limit spec means the IC can survives the condition that the driver output shorts to Ground continuously. But the IC can not work properly at its outputs shorts to ground.
Thanks
Best Regards,
Zhongmin Yu
