MAX490
Production
The MAX481, MAX483, MAX485, MAX487–MAX491, and MAX1487 are low-power transceivers for RS-485 and RS-422 communication. Each part contains one driver and...
Datasheet
MAX490 on Analog.com
MAX33046E
Production
The MAX33045E/MAX33046E is a half-duplex RS-485/422 transceiver that operates at either 3.3V or 5.0V supply rail for ease of design. Both devices feature...
Datasheet
MAX33046E on Analog.com
MAX33048E
Recommended for New Designs
The MAX33047E/MAX33048E/MAX33049E are ±40kV
ESD-protected full-duplex RS-485/RS-422 transceivers
that operate from 3.0V to 5.5V and provide design
flexibility...
Datasheet
MAX33048E on Analog.com
Hi everyone,
ı need a UART TO RS485/RS422 converter. I found MAX490 tranciever-reciever IC but ı have questions. Can ı use the MAX490 for RS485 and RS422 ? ı dont see any information and aplication for rs422 in the datasheet. Also Can I use half dublex rs485 and full dublex rs422 with MAX490 IC in different times?
Thank you, your answers.
Yes, MAX490 can be used in RS-485 and RS-422 systems. The specifications in the datasheet apply to both RS-485/RS-822 protocols. In order to convert a full duplex transcerver to a half duplex mode, you have to use external switch to combine Diver and RX bus into a bus. you can consider LTC2870/71, which can be configured to half or full duplex. More ADI interface transceivers available for you to choose from, such as MAX33046E, MAX33070E/71/72; MAX33048E...
Thanks
ZYU
