LTC1688
Production
The LTC1688/LTC1689 are ultrahigh speed, differential bus/line drivers that can operate at data rates up to 100Mbps. Propagation delay is guaranteed at...
Datasheet
LTC1688 on Analog.com
In our application LTC1688 planned to be used as RS422 driver with interconnecting cable of length 20meters and above approx. For standard 24 AWG twisted pair cable capacitance was calculated to be 1.38pf/inch which will provide cable capacitance of nearly 15nf differential between P & N signal of RS422
However in datasheet its mentioned capacitance of load to be below 220pf for proper operation
"A time-out period of about 50ns is required before a shortcircuit fault is detected. This circuitry might falsely detect a short under excess output capacitive load (>200pF). Additionally, a short might go undetected if there is too much resistance (user inserted or cable parasitic) between the physical short and the actual driver output."
Kindly check and provide feedback for this case and usage of device in such condition
It means the capacitance right at the IC output pin. Cable characteristics consists of RLC. Ideally the characteristic impedance of the cable being used should match the load impedance, such as 100ohm, to avoid signal reflection/loss.
Thanks
Best Regards,
Zhongmin
