Hi support team
Regarding ADM485, what is the resistance value between pins A and B when VCC is not applied?
Is it 2kΩ ,or is it a high resistance?
If it is high-Z , what is the actual resistance value?
KCC's Quizzes AQQ306 about a fish stick challenge
1. First the quote of the month: " I am so clever that sometimes I don't understand a single word of what I am saying" - Oscar Wilde
2. New quiz AQQ306 about a fish stick challenge:
Here below is a pseudo fish diagram swimming to the right.
Question
Strong EMC design
ADM485
Production
The ADM485 is a differential line transceiver suitable for high speed bidirectional data communication on multipoint bus transmission lines. It is designed...
Datasheet
ADM485 on Analog.com
Hi support team
Sorry, 2k ohm was incrrect.
I mean 12k ohm below.
When without VCC, the A/B lines should be high Z, at least 10kohm. But it will varies with voltage being applied to the port since the internal circuitry will be turned on if the voltage high enough.
Thanks
Zhongmin
Thank you for your helpful answer.
I understand.
