ADUM4135 Schematic Review
Product Number: ADUM4135
Please review the schematic for ADUM4135 IC. DCBUS is 28VDC. Driving mosfet is VS-FC420SA10.
Thanks.
  • Hi ali.kaan,
    Thank you for using the ADuM4135 in your application.
    Looks good to me aside from the local decoupling capacitor that will be put close to the ADuM4135 supply pins.
    I suggest you add 0.1uF close to the VDD2/VSS2 to GND2. Also, D14 should be a fast recovery diode.
    regarding the DESAT circuit, I believe you will be doing some minor adjustments here to get the right desat response but the configuration looks good.
    May I know what is your application?
    Thanks and regards,
    Jefferson
