Hi
Is there any document with informations about Reliability, MTBF etc.. of the AD74413?
Hi
I am working on your request and will clarify presence of the document internally.
Arnost
please use the following link: Wafer Fabrication Data | Analog Devices
On web page: Insert required PN of the part "AD74413R" and click submit. It should show you relevant data.
Please let me know, if this answers your question and if there is anything else I can help with.
Arnost
Dear Mr. Plavic
thanks for your reply. As you might know, we need evidences on how these values are considered. For IEC61508 safety application we need to show to Notify body explanation and procedure on how the data inside the table are calculated. Do you have a specific reports with more details on how you tested the samples?
Thanks for support
I am in process getting answer for you.
So far I have only following answer from Reliability team: " FITS calculations are standard across the industry – and we do/calculate it using the HTOL tests done on the process (thus the link shared)."
As I assume, maybe you are looking for different inputs.
I am going to ask our person involved in safety application to see, what we will be able to provide.
Regards.
Arnost
Many thanks Arnost. Awaiting your colleagues feedback.
I was directed to the https://www.analog.com/media/en/technical-documentation/user-guides/UG-311.pdf (pages 14 to 16)/. Concerning the calculations.
Does it provides sufficient information you are looking for?
Arnost
