Using Can FD with Standard CAN 2.0AB traceivers
The user inquired about the compatibility of CAN-FD with CAN2.0 transceivers. The final answer confirmed that a CAN-FD transceiver, such as the LTC2875, can be used in a CAN2.0B or CAN2.0A network, but a CAN2.0 transceiver may not support CAN-FD. The LTC2875 is recommended for CAN FD networks and is pin-compatible with the ADM3051.
Category: Datasheet/Specs
Product Number: ADM3051
Software Version: na
Hi ,
I just want to make sure about using  CAN-FD on a CAN2.0 Tranceiver like ADM3051, in essense CAN-FD is high speed with Flexible data rate .
However if you still run CAN-FD at 1Mbit can you still use a CAN2.0AB traceiver? also the reverse question, can you use a CAN2.0AB  with CAN-FD tranceiver?
regards
Conrad
  • Hi Conrad,
    A CAN-FD transceiver can be used in a CAN2.0B or CAN2.0A network. CAN-FD compliant transceivers will be backwards compatible. The reverse may not necessarily be true. For a CAN FD network, I recommend evaluating the LTC2875 which is available in an 8L-SOIC_N pin-compatible with the ADM3051.
    Jason
