My PCB was working fine but then it suddenly stopped working. When I checked the pins of ADP1031 with multimeter, I measured 2 Ohm resistance between SVDD and SGND pins.
The problem was gone when I replaced the ADP1031 with a new one. With the new ADP1031 the resistance between SVDD and SGND is in kilo Ohm range.
Now on another PCB I was testing, I measured 2 Ohm resistor between SGPO and SGND pins. This again prevents the PCB from working as expected.
I think this problem will also be solved if I replace the ADP1031.
My question is, have you ever had the problem that one of the GPO pins or one of the SVDD pins of the ADP1031 looks like internally shorted to ground over a 2 Ohm resistor?
Does it defientely mean that the ADP1031 chip is permanently damaged? Can this damage simply be caused by electrostatic charge or should I look for a more serious issue with my PCB that might be damaging the ADP1031 chip?
Thank you very much for your help.
Best regards.
Changed category from software to hardware
[edited by: bahadirdonmez at 5:50 PM (GMT -4) on 16 May 2022]
