Using LTC2873 with VEE = 0V
The user inquires about running the LTC2873 with external Vdd = 5V and Vee = 0V supplies to achieve 0V/5V RS232 output levels. The final answer confirms this is possible by removing the charging capacitor between CAP and SW pins and the inductor between SW and VCC pins, allowing external power supplies to be used. The SW pin will continue to switch but will not generate internal VDD and VEE supplies.
Is it possible to run LTC2873 with external Vdd = 5V and Vee = 0 V supplies? The target is to use RS485 normally but to get RS232 output voltage levels to 5 V and 0 V. Then the RS232 mode would provide a general 0V/5V GPIO not fulfilling the RS232 specs.
  • While I haven't tested this exact voltage combination myself, this combination should work well with the LTC2873.
    The charging capacitor between the CAP and SW pins, and the inductor between the SW and VCC pins should both be removed. The SW pin will remain switching, but without connections to the CAP and VCC pins it will not generate VDD and VEE supplies internally. VDD and VEE can then be powered externally with the 0V and 5V supplies.
    Neil
