About connection between ADN4680E and FPGA
Hi all,
We are considering the following configurations using ADN4680E.
We want a direct connection between the ADN4680E and the FPGA.
Is this method correct?
Or should we also use a Buffer IC or something like that?
If there are any problems, it would be great if you'd let me know.
Best Regards,
Hiro
Parents
  • Hi Hiro,
    This configuration is perfectly valid.
    The 3.3V I/O bank of the FPGA can be connected directly to the digital DI, DE, /RE, RO, /FS and ENP pins of the ADN4680E, no buffer IC is needed.
    If you which to use lower voltage I/O banks on the FPGA, a level shifter like the ADG3246 can be used to interface with the ADN4680E.
    Neil
Reply
  • Hi Hiro,
    Neil
Children
