ADM2867E RS 422 Transceiver
The user asks about the necessity of connecting the isolated ground to the chassis through an RC filter when interfacing RS-422 channels between two systems. The final answer suggests that the user should share the required diagrams via email for a detailed review, as the file attachment feature is not working. The accompanying answer confirms that the files have been sent for review.
scenario 1
I am interfacing RS-422(Isolated) channels of two systems with each other and  each system has RS-422 which have five wires i.e Tx-, Tx+,Rx-,Rx+ and Ground as show in attached diagram (File name : Both_System_ADM2867)
Q1:Did we need to connect ground (isolated) to chassis through RC filter in each system (File name: Both_System_ADM2867 with RC filters) ? is it necessary? what are the advantages and disadvantages of it? or it's work okay as it is shown in diagram( File name : Both_System_ADM2867)? Kindly give reason of it .
scenario 2
1) one system has RS-422 which have five wires i.e Tx-, Tx+,Rx-,Rx+ and Ground
2) Second system has RS-422 which have ffour wires i.e Tx-, Tx+,Rx-,Rx+
as show in attached diagram (File name : Rs 422 five wires and 4 wires)
Q2: Did we need to connect ground  to chassis through RC filter in system which has five wires  ? or with out RC filter its work okay ? Kindly give reason of it .
