ADuM1400 & ADuM3400 ESD HARDENED
Hi
A customer asks me about the ADuM3400.
The ADuM3400 is said to have better ESD immunity in the system than the ADuM1400.
(By ADuM3400 Datasheet & AN-793)
In the link below, there is no problem with 8kV for contact discharge and 15kV for air discharge,
Is this value mentioned in any document?
https://ez.analog.com/cn/interface-isolation/f/q-a/60233/adum3400-adum1400-esd
I would like to know the reason why the ADuM3400 is stronger against ESD and latchup than the ADuM1400.
(Are you just designing and improving and not specifying the ESD torrerance? Or is the standard of the ESD torrerance cleared is different?)
Yuya
    on Jun 5, 2020 1:10 PM 10 months ago
    Hello Yuya
    Your questions take some research to answer.  The person who has all of the details is the designer of those devices, and he will not be available until Monday.  I will follow up on this when he is back "in the office".
    Best Regards
    MSCantrell
    on Aug 12, 2020 4:03 PM 7 months ago in reply to ADIApproved
    Hello Yuya
    The ADuM1400 was intended for use inside a system where the I/O is not exposed to direct ESD strikes.  The ESD protection is geared toward handling in manufacturing, rather than operation in the final application.
    The ADuM3400 series uses the same basic ESD structure internally, but care was take with layouts and bond wires to enhance the tolerance to ESD strikes.  ESD design is heavily dependent on how the protection is implemented in addition to the types of structures used.
    Best Regards
    MSCantrell
