ADM3057E VIORM definition
Hi ADIExpert
I have a ESS system as below functional block, one battery stack is composed of 14 series packs that provides voltage up to 1kV
each battery pack is communicated with  master control board with iso CAN bus implemented by ADM3057E
May I know in this scenario, how do we define VIORM of ADM3057E?
on the other hand, Is there any constrain on the stackable ADM3057E in this system architecture?
thank you
Ken
Parents
  • +1
    on Feb 26, 2020 5:31 PM over 1 year ago
    Hi Ken,
    Viorm is the working voltage based on 50/60Hz line voltages. It sounds like this may be a DC application so Table 11, Maximum Continuous Working Voltage in the ADM3055E/ADM3057E datasheet may be a better guide here.
    An isolator is actually two parallel isolation systems. There is the signal path with planar transformers and then there is the packaging. The packaging isn't particularly glamourous but its necessary and makes good place to start. To figure out what is needed for packaging, we need to look at where people may come in contact with the system and determine if we need basic, reinforced (or double) insulation. Then consider the pollution degree, and the standards that need to be met. This should give us the minimum creepage requirements.
    Then consider the signal path with the information in Table 11.
    Jason
Reply
  • +1
    Hi Ken,
    Jason
Children
No Data
