Where can I find IBIS model for ADuM141ES? Or it is the same as for ADuM141E?
ADUM141ES
Recommended for New Designs
The ADuM141ES are quad-channel digital isolators based on Analog Devices, Inc., iCoupler® technology. Combining high speed, complementary metal-oxide semiconductor...
Datasheet
ADUM141ES on Analog.com
ADuM141E
The ADuM141E1 is a quad-channel digital isolator based on Analog Devices, Inc., iCoupler® technology. Combining high speed, complementary metal-oxide...
ADuM141E on Analog.com
Hi there,
Unfortunately, there is no IBIS model for the space-grade ADuM141ES at this time. I'll also note that the two devices are not exactly the same, so using the IBIS model for the commercial-grade ADuM141E would not yield accurate results.
Is there any information available about the output impedance of the VOA, VOB, VOC and VOD outputs? I would like to best match the output impedance to the trace transmission line impedance.
