Hello;
Does ADG3231 output pin have internal pull-down or pull-up resistance and what is the resistance value? Thank you very much!
regards;
Bell
ADG3231
Production
The ADG3231 is a Level Translator designed on a sub
micron process which operates from supplies as low as
1.65 V. The device is guaranteed for operation...
Datasheet
ADG3231 on Analog.com
Hello;
regards;
Bell
Hello Team;
Do you have any feedback to above questions?
Many thanks;
Bell
Hi Bellye,
The ADG3231 does not have any pull-up nor pull-down internal resistors.
May
Hi May;
Got it; Thanks for your reply.
regards;
Bell
