LTC4301L
The user needs to level translate an I2C bus from a 3.3V microprocessor master to a 1.2V FPGA slave. The final answer confirms that Vcc should be tied to the 3.3V supply, with SDAIN and SCLIN connected to the 1.2V bus, as shown in the middle configuration of Figure 3. Both data and clock lines are bidirectional.
I need to level translate an I2C bus from a uP master at 3.3V down to a 1.2V slave for an FPGA.
Thus the uP is master and drives SCL and SDA into the SCLOUT and SDAOUT pins.  Does this actually work that the SCL drives into SCLOUT and out of SCLIN?
It does appear that both the data and clock are bidirectional and can drive either direction.
Does this sound correct?
