This discussion has been locked.
You can no longer post new replies to this discussion. If you have a question you can start a new discussion
About ADIN1300
The generic Linux driver can support the ADIN1300 chip using the first 16 generic registers. The current driver is compatible with Linux kernel 4.19 and not backwards compatible with earlier versions. The ADIN1300 can connect to multiple MAC interfaces including MII, RMII, and RGMII.
1. Can the Generic Driver of the Linux kernel drive this chip?
2. Does the driver provided on the official website support linux3.10 kernel?
3. Can the chip be connected to EMAC?
Edit Notes
[locked by: CatherineR at 8:35 AM (GMT -4) on 3 May 2023]
  • Hi Geoff,
    Yes the generic Linux driver can be used with the ADIN1300 as long as the only registers being used are the first 16 generic registers.
    The current Linux driver available is compatible with version 4.19 and is not backwards compatible.
    The ADIN1300 can be connected to multiple MAC interfaces such as MII, RMII and RGMII.
    Best Regards,
    Mark
