a. Ethernet IP (Industrial Protocol to act as IO device and Communicate with Allen Bradley PLC)
b. Profinet (Act as IO device and communicate with Siemens PLC)
c. Dual network ports (Device Level Ring, DLR preferred) or provided and integrated Ethernet
switch on the PCB is desired to facilitate daisy chain configuration for Ethernet
communications.
d. Method to set static IP address, Method to reset IP to default
My sensor are basically pressure sensor module with I2C communication.
Sanket
