What type of support can I expect from ADI while I am incorporating the RapID Platform reference design into my product?
| SLA Status | Assignee | Support Status |
| SLA Closed. | Open | |
FIDO1100
Not Recommended for New Designs
fido1100 is the first product in the fidoâ„¢ family of real-time communication controllers. The fido communication controller architecture is uniquely...
Datasheet
FIDO1100 on Analog.com
Customers tell us our support and tools are better than anything they have used before! We are available from the time you start evaluating the RapID Platform all the way through certification of your device. Regardless of the question, we are a one-stop shop that gets you answers on anything related to the RapID Platform—from a detailed EtherNet/IP question to a low level firmware timing question—you get the answers to make your product a success. And our support doesn’t stop there. We continuously protect the RapID Platform from obsolescence, and we continuously maintain the protocol stacks. We also provide regular updates to the fido1100 firmware and software libraries. You won’t be left watching vendors pointing fingers at each other and making you figure out why their solution doesn’t work.
Dear Team, Am not able to find the EDS files and other resources for RAPID V2X09 the same in the website. Will be glad if you could incorporate the same in the website else a download link.
I'm planning to use RapID Platform in my products, but I found that the FIDO1100 is "Not recommended for new projects" and the FIDO5000 (that is used in the devkit) is not anymore available.
Now I'm a bit confused: all the reference electrical schemas are useless beacause I have to buy FIDO5100 or FIDO5200 and also all the firmwares will not work.
So, integrating the RapID Platform in my boards will not be easy if you don't upgrade all the schemas and all the firmware.
Please let me know if ADI has planned to maintain this platform or not.
Best regards
Massimo Marolda
Hi Massimo,
Can you please advise on your Industrial Ethernet protocol you are planning on using?
The EDS file can be found for download in the ADI Chronous Developer Portal.
https://www.analog.com/en/gated/developer-portal/network-interface-rems.html
Once you have logged into the Portal, please download the zip file with the following title.
EtherNet/IP RapID Platform with REMS Software
The EDS file can be found in that zip file in the following directory structure:
"Examples\Config\Basic_DLR\REM"
The name of the file will be:
" Basic_EIP_demo_cfg_REM.eds"
Please let me know if you have further questions.
Hello DET_CStelmar.
I want to access the ADI Chronous Developer Portal to use the REMS Software but I get everytime the message:
"Ohm my! You are not Authorized for the Requested Page"
I am logged in in MYANALOG-account. What I have to do, to get the access?
best regards!
You have to register for the Developer Portal.
Industrial Ethernet Platform Solutions | Analog Devices
Click on "Register Now" and the Developer Portal Support Team will be able to get back with you regarding your registration.
