ADIN2111
Recommended for New Designs
The ADIN2111 is a low power, 2-port 10BASE-T1L transceiver designed for industrial Ethernet applications, and is compliant with the IEEE® 802.3cg-2019...
Datasheet
ADIN2111 on Analog.com
In ADIN2111 Datasheet page 51. (Cut Through Transmit Latency) The example calculates a Transmit Latency of 7.2us.TX_THRESH = 1 (Means 1 half word has to be sent = 16 bit = 2 Bytes)SPI Freq = 16MHz -> Bit time = 62,5ns -> Byte Time = 500ns.PHY Transmit Latency = 3,2us
The Open Alliance header is 4 Byte, so we have to send 6 Bytes in total (4 Header Bytes + 2 Bytes "Half word").
6 Bytes * 500ns + 3,2us = 6,2us.
Is there anything I'm forgeting?
Hi inagore
Thanks for pointing that out.
The above transmit latency of 7.2us is correct for RevA generic SPI protocol. The 4 byte RevA TxHeader, followed by the two byte frame header and the 2 TX_THRESH bytes have to be transferred over the SPI before the frame transmission can start in the PHY, i.e. a total of 8 bytes, which would take 8 * 8 * 62.5 ns = 4,000 ns = 4 us + PHY Tx latency = 3.2uS
Total Tx Latency = 4us + 3.2us = 7.2us
For OA SPI protocol, the latency measured from the first bit following the (OA-SPI) TX header and TX_EN assertion is between 1.4us and 1.8us. Including the 4 bytes (2 us) Rev B Tx header, this adds up to 3.4uS and 3.8us which brings the total Tx latency to around 6.8us.
The 2 byte of TX_THRESH accounts for 1us. The variable part (0.4us to 0.8us) is due to the transfer between 62.5 ns SPI clock domain and the 400 ns MII TX_CLK clock domain. It is between about 1 and 2 MII clock periods and is probably due to some TX FIFO.
The SPI clock is a 16 MHz clock and the MII clock is a 2.5 MHz clock, so even though they are synchronous they do not have a fixed phase relationship.
Hope this helps.
Shazia
