ADIN2111 evaluation board frame cheker on terminal
The user asked about the meaning of RX, Diff, and Err in the output of the Frame Generator/Checker demo on the EVAL-ADIN2111EBZ and EVAL-ADIN1100EBZ evaluation boards. The final answer explained that RX is the number of received frames, Diff is the difference between sent and error-free received frames, and Err is the number of frames with errors. To change the status of RX, Diff, and Err, the user should ensure the board is linked to a partner in MAC remote loopback mode, and to make Diff non-zero, disconnect the cable during the test.
Product Number: ADIN2111
Hello
I have the evaluation board of ADIN2111 and ADIN1100.
I tried to do the frame generator /checker demo using Fixed IP  referring to URL "wiki.analog.com/.../eval-adin2111ebz-user-guide "
I could show below on terminal
Could you tell me know what RX, Diff and Err means ?
(If possible, could you tell me how I can change the status of RX,Diff , Err =0 )
start
OK
CH1 -37.2 dB,CH2 MSE n/a , Rx 0, Diff 0, Err 0
stop
OK
Teli
  • Hi Teli,
    When you configure and run the Frame Generator/ Checker, the firmware provides an output where:
    • MSE is the 10BASE-T1L mean square error, which indicates link quality.
    • Rx is the number of Ethernet frames received by the PHY from the 10BASE-T1L cable since the last board or firmware reset.
    • Err is the number of frames with error received since the last board or firmware reset.
    • Diff is the difference between frames sent and frames without errors received.
    The "Rx" output is generated when the frame generator / checker mode is enabled on EVAL-ADIN2111EBZ Port1 or Port2. That port must be linked to a partner configured in MAC remote loopback mode. You can use the EVAL-ADIN1100EBZ configured in MAC remote loopback or if you're using just the EVAL-ADIN2111EBZ, this could be the second port on the same board.
    If you want "Diff" <> 0, disconnect the cable from the port in the middle of the test running. You may also see Err > 0, if you manage to pull the cable in the middle of a frame. The Diff = 0 indicates that the test is running as expected.
    Shazia
