ADIN1200 No Linking/Autonegotiation timing problem
Hey all,
i have a problem with my ADIN1200 RMII media converter design. I want to use the ADIN1200 an another Phy in my media converter.
As reference design i used this one:
https://github.com/ArrowElectronics/10BASE-T1L-MC/tree/main
This is my Schematic. It is nearliy the same as the reference:
I set this register entries:
PHY_CTRL_2 = 0x0400
PHY_AUTONEG_ADV = 0x0041
MII_CTRL = 0x1300
LED_CTRL_1 = 0x0401
LED_CTRL_2 = 0x2109
It is suspicious that the timing of the reference design is different from the timing of my design.
Maybe because of this autonegotiation is not working and there is no link.
Here is the timing from the working reference design:
And this is the AN timing of my design:
Maybe someone has an idea what the problem could be. It looks like a configuration problem to me,
     The schematic that you have provided looks to match with the Reference Design. Have you performed the required ADIN1200 Register writes to enable the ADIN1200 to operate as a Media Converter? Please see below for a description of the register writes needed to configure the ADIN1200 for Media Converter applications.
    • RMII RX/TX interfaces are not functionally compatible (not supported by the RMII specification), so by default aren’t intended to be connected back to back directly. However, there is a bit field provided in the ADIN1300 which allows configuration of back to back mode with the RMII interface. If connecting the ADIN1300 to another ADIN1300 (or ADIN1200), set GE_RMII_CRS_EN to 0 in the GE_RMII_CFG register. This will disable CRS encoding on CRS_DV, so it can be connected to TX_EN.
    • In 10BASE-T mode and with any of the MAC interfaces, the 10BASE-T receiver can remove several preamble bits, so the RX data would have <7 preamble bytes. This could cause problems for the remote end receiving the frame. To avoid any issues, enable the 10BASE-T RX preamble re-generation by setting the GE_B10_REGEN_PRE register (address 0xFF38) to 0x1.
    The register redback that you have provided, are they from your board, or are they from the working reference design board?
    Is the link partner you are connecting too also Advertising 10M speeds?
    Could you provide register readbacks from the ADIN1200 for Registers 0x00 to 0x1F from your design?
    Best Regards,
    Mark
  • Hi Mark,
    thanks for your reply.
    These Settings are set, but the problem is still there.
    These are the same for both boards.
    I think so. 100M definetly. The Dev Board is working with the same partner.
    Here the register readback:
    07:17:58.346 -> Phy:8, Reg:0, Value:1100
    07:18:02.133 -> Phy:8, Reg:1, Value:7949
    07:18:06.303 -> Phy:8, Reg:2, Value:283
    07:18:10.166 -> Phy:8, Reg:3, Value:bc20
    07:18:13.630 -> Phy:8, Reg:4, Value:45
    07:18:16.860 -> Phy:8, Reg:5, Value:0
    07:18:19.733 -> Phy:8, Reg:6, Value:64
    07:18:23.161 -> Phy:8, Reg:7, Value:2001
    07:18:26.707 -> Phy:8, Reg:8, Value:0
    07:18:30.058 -> Phy:8, Reg:9, Value:0
    07:18:35.507 -> Phy:8, Reg:A, Value:0
    07:18:39.366 -> Phy:8, Reg:B, Value:0
    07:18:49.860 -> Phy:8, Reg:C, Value:0
    07:18:55.665 -> Phy:8, Reg:D, Value:0
    07:18:59.626 -> Phy:8, Reg:E, Value:0
    07:19:03.195 -> Phy:8, Reg:F, Value:0
    07:19:10.167 -> Phy:8, Reg:10, Value:0
    07:19:16.211 -> Phy:8, Reg:11, Value:0
    07:19:20.408 -> Phy:8, Reg:12, Value:402
    07:19:23.792 -> Phy:8, Reg:13, Value:1051
    07:19:29.394 -> Phy:8, Reg:14, Value:0
    07:19:32.598 -> Phy:8, Reg:15, Value:1
    07:19:36.057 -> Phy:8, Reg:16, Value:400
    07:19:39.355 -> Phy:8, Reg:17, Value:3048
    07:19:42.740 -> Phy:8, Reg:18, Value:1
    07:19:46.062 -> Phy:8, Reg:19, Value:100
    07:19:49.701 -> Phy:8, Reg:1A, Value:304
    07:19:54.154 -> Phy:8, Reg:1B, Value:401
    07:19:57.203 -> Phy:8, Reg:1C, Value:2109
    07:20:01.014 -> Phy:8, Reg:1D, Value:1855
    07:20:04.901 -> Phy:8, Reg:1E, Value:0
    07:20:09.757 -> Phy:8, Reg:1F, Value:83fc
    Simon
  • Found the Problem in the TXEN Pin.
    Interesting is, that Auto Negotiation won't work with a false TXEN Signal. Linking without AN was possible.
    --CLOSED--
  • Hi Simon,
    Thank you for the update.
    Best Regards,
    Mark
