This discussion has been locked.
You can no longer post new replies to this discussion. If you have a question you can start a new discussion
ADIN1300 CLK_IN voltage range
In the datasheet, Clock Input Voltage Range (CLK_IN)  is 2.5V(max)
Does this mean I need to input clock signal whose voltage swing is lower than 2.5V?
in that case, what is the minimum voltage range of CLK_IN ?
[locked by: CatherineR at 4:32 PM (GMT -4) on 22 Oct 2021]
  • Hello,
    Thanks for your message.
    The ADIN1300 can support an external clock in the range 1.62V to 3.63V, so can support a clock source from 1.8V, 2.5V or 3.3V.
    The supply to the XTAL circuit is always 3.3V as it is fed from the AVDD_3P3 supply rail.
    We are in the process of revising the datasheets, so this will be updated in the next revision.
    best regards,
    Catherine.
