Regarding the PRP configuration on ADIN6310
Product Number: ADIN6310
Software Version: na
When configuring two ports as PRP (Parallel Redundancy Protocol) nodes, does the switch support the forwarding of broadcast packets across the PRP network?
  • During our testing, we observed that only unicast packets were being forwarded successfully.
  • Please clarify whether broadcast and multicast traffic are expected to be supported in this configuration.
Thread Notes
  • Hello,
    That is correct, broadcast traffic is not forwarded by default, user must configure by adding a static entry.
    Let us get back to you next week with further info,
    best regards
    Catherine.
  • Hello,
    Could you please share the setup details and the expected broadcast/multicast traffic path?
    Are you expecting the broadcast/multicast traffic received on the PRP ports (LRE ports) to be forwarded to Port C?
    By default, broadcast/multicast packets received on the LRE ports are not forwarded to Port C in a PRP configuration. To enable this forwarding, you need to install an appropriate static entry.
    For reference, please see the "INSTALLING STATIC ENTRY TABLE FOR BROADCAST TRAFFIC" section in the PRP configuration of the Driver User Guide, which provides an example of configuring the required static entry.
    Please let us know if this helps, or if you are observing a different issue.
    Himanshu
