No voltage on the DLDO1_1P1
The user encountered an issue where the DLDO1_1P1 output was 0V on the ADIN2111, despite no shorts to ground. The problem was resolved by correctly connecting the AVDD_L pin (Pin 36) in the schematic. The datasheet should have clarified that AVDD_L supplies the DLDO1_1P1 internal regulator.
Product Number: ADIN2111
Hello there,
has anyone encountered this problem? The same rail, 3.3V, is used to supply the ADIN2111 AVDD_H, AVDD_L, and VDDIO supply rails. Both DVDDx_1P1 1.1 V rails are being supplied from their internally DLDOx_1P1 1.1 V power supplies. There is an output voltage of 1.1 V on the DLDO2_1P1, but the DLDO1_1P1 output is 0 V. There are no shorts between DLDO1_1P1 and DVDD1_1P1 pins to the ground or any other pins or traces.  Do you know what the problem might be? Your help is greatly appreciated.
