Switch configuration modification after initial configuration
The user inquires about reconfiguring SFP module ports on a switch while powered on. The final answer states that this is not possible and requires either a reset or power cycle of the switch. This is a known limitation, and a future update to address it is under consideration.
Product Number: ADIN3310
Software Version: Rev 5.0
Is there a way to reconfigure the ports after they are initially configured?
Our design utilizes SFP modules and so we will need to change the port media interface in the port configuration when these modules are changed and because SFPs are hot pluggable, this needs to happen when the device is powered on.
Thank you
