We are looking into using PROFINET TSN over Ethernet APL, 10 Mbit Power Over Data lines. From a hardware perspective, what would be required of the MCU to handle TSN? And does analog have solutions for this? i guess ADIN1100 can be used as PHY.
ADIN1100
Recommended for New Designs
The ADIN1100 is a low power, single port, 10BASE-T1L transceiver designed for industrial Ethernet applications and is compliant with the IEEE® 802.3cg...
Datasheet
ADIN1100 on Analog.com
DET_CStelmar - Moved from Ultra Low Power Microcontrollers to Embedded Ethernet Switches. Post date updated from Friday, September 13, 2024 11:19 AM UTC to Monday, October 21, 2024 5:34 PM UTC to reflect the move.
I will look into this question and get back to you soon on this topic.
Thank you very much.
Best Regards,
So one point of clarification. Are you looking for a solution to support PROFINET over TSN on a platform? I.E. a solution ADI has the supports "Profinet Class D"?
Or are you looking for an IC to embed in your platform that has capability to support TSN features.
If its the latter can you please tell me which TSN features you are going to look to support?
So basically we are looking for a an MCU that can support PROFINET TSN and more precisely, enhanced synchronization behavior since we will have multiple units on a bus that we would like to be synchronized. From the MCU, we plan to then hade a ADIN1100 in between the MCU and the bus.
