Table 8 in datasheet rev A has conflicting SPI_CFG0 description: PU/PD column lists PD but in "Description" column pull-up is listed.
Which one is true?
ADIN2111
Recommended for New Designs
The ADIN2111 is a low power, 2-port 10BASE-T1L transceiver designed for industrial Ethernet applications, and is compliant with the IEEE® 802.3cg-2019...
Datasheet
ADIN2111 on Analog.com
Which one is true?
Hi Tomasz,
Thanks for reaching out.
The correct information is that the pin is PULLED DOWN by default, and the reference to a pull up resistor in the description will be corrected in the next revision of the datasheet.
Kind regards,
Shazia
Thank you for the reply.
Would it be worth reporting other mistakes in documentation or are they well known already?
There are mistakes in tables 33...36 (bit indexes ending on even number in each table because ADDR12:0 indexes are wrong in tables 33, 34, 36 and bit 71 duplicated in table 35).
Hi Tomasz,
The typos you pointed out have been noted. Your feedback is greatly appreciated, definitely useful to receive input of this nature.
Thanks for reporting this.
Kind regards,
Shazia
Hi Tomasz,
I have checked those tables and you are right. Thanks for spotting those typos. They will be included in the changes for the next revision of the datasheet.
Appreciate your feedback.
Kind Regards,
Shazia
Hi Thomasz,
Your feedback is vital to us, and we're grateful for your input. If you ever have more questions or need assistance, feel free to reach out. I will be closing this thread now.
Shazia
