Network Interface module RAPID-NIEK-V0004
I have loaded the MBS_demo_cfg.load using bootloader on my Network interface module.  I then used the NI_Test_IO.exe. but nothing is appearing after " Initializing module to use basket 1000". Attached here is the screenshot of it. I was expecting the DHCP server to assign an IP address to it. I have connected my Network interface to the wifi router. I have attached a photo of the error
  • Hello,
    So when using NI_Test_IO, one of the things that needs to be supplied is a -u for the COM port in use. Modify the arguments you are supplying as shown in the screenshot to match the following.
    Instead of "NI_Test_IO comX"
    use
    "NI_Test_IO -u comX"
    There is another potential thing to consider in that NI_Test_IO will not handle a COM port number above 9 right now.
    Please try out the suggestion as shown and let me know how it works.
    Thank you very much.
    Best Regards,
  • I executed the above-mentioned command with com 7 and that was the port confirmed through the device manager. The output on the command prompt was :
    C:\Analog Devices\Network_Interface_ModbusTCP-Rel0.0.8\HostComponents\NI_Test_IO\Release>NI_Test_IO-u com7
    'NI_Test_IO-u' is not recognized as an internal or external command,
    operable program or batch file.
  • Hello,
    Can you please show me a printout when you run the following command?
    NI-Test-IO.exe -h
  • C:\Analog Devices\Network_Interface_ModbusTCP-Rel0.0.8\HostComponents\NI_Test_IO\Release>NI_Test_IO.exe -h
    Welcome to NI_Test_IO, version 1.3
    Error: Extra, missing or incorrect command line arguments
    Usage:
    NI_Test_IO [-v] [-uxxxx] [-txxxx] [-bxxxx]
    [-rxx] [-lfilename] <communication port name>
    items in angle brackets <> are required.
    items in square brackets [] are optional:
    -v = tool runs in verbose mode
    -uxxxx = echo server uses UDP (-u) on the specified port
    -txxxx = echo server uses TCP (-t) on the specified port
    -bxxxx = specifies basket ID, default is 1000
    -rxxxx = specifies a reset delay in seconds, default is 10
    -lfilename = turns on logging to the file named
    communication port name is not optional
    Example:
    NI_Test_IO -v -b100 -u com1
  • Hello,
    OK I think I understand what is going on from here.  The line broke in your reply so I didn't quite catch on to this.
    "NI_Test_IO-u com7" should be "NI_Test_IO -u com7".
    If this does not fix the issue for you, please provide your email and I will reach out and assist you further.
    Thanks and Best Regards,
  • I have attached the image of the result for the execution of  "NI_Test_IO -u com7". It is stuck at basket initialization. Please reach out to me at alokkum@vt.edu
  • Hello,
    I will reach out to you in email. Please try one more thing before we begin that dialogue offline.
    Please try pushing the "RESET" button the evaluation kit before running NI_Test_IO with the arguments you have posted.
