TSN evaluation Kit(RapID-TSNEK V0001)
The user is unable to connect to the web interface of the evaluation kit using the IP address 192.168.1.1 and cannot access the bootloader files. The final answer suggests verifying the Command Prompt is run in administrator mode and requests an email for further troubleshooting.
Hi All,
I am not able to connect to the web interface of the evaluation kit. The IP address mentioned in the document is 192.168.1.1. Tried all the possible means bit unable to find the IP address of the board.
I am not able to access the bootloader files for the board too. Its a very urgent issue. So please help me.
Thanks and Regards,
Naveen Alexander
  • Hi Naveen,
    If you are trying to access the bootloader from the board, this is likely a permissions issue. Please verify you are running the Command Prompt elevated or in administrator mode.
    If this does not solve the issue, then please provide an email and I will reach out with next steps for troubleshooting.
    Thanks and best Regards,
