1.Quote of the month: "People Who Say They Sleep Like a Baby usually don't have one" - unknown
2. New quiz AQQ302 about Band Gap Reference Voltage generation. OK this one is probably more dedicated to our IC designers...
Good Luck!
Good Luck!
We need the slope wrt to T of 86E-6*T*ln(I1/I2)=.0018. Thus
ln(I1/I2) = 0.0018/86E-6 = 20.93. Then I1/I2 = e^(20.93) = 1.23E9. While doable in these days of Amps and nAmps on the same chip, this is a ridiculous ratio.
So G*ln(I1/I2) to the rescue to reduce that factor of 20.93.
G = 20.93/ln(3) = 19.05. Easy to do with an opamp and some well matched resistors.
Q1 .
If I1 > I2, ln(I1/I2) is positive and VBE1-VBE2 is positive to compensate the fall of Vbe with T.
Q2.
For an increase of temperature of 1K, Delta Vbe =k/q Ln(I1/I2).1= 86 10^-6.Ln(I1/I2) witch must compensate -1,8 mV. So, we have:
Ln(I1/I2)= 0.0018/0.000086 ≈ 20.93 so I1/I2=e^20.93 ≈ 1229941640.1
Q3.
If I1/I2 =3, the gain G of the amplifier is 20.93/Ln(3) ≈ 19.0515
Q1. I1 > I2 because Ln(I1/I2) must be +ve. Real band gap references don't vary the current - they vary the current density by increasing the junction area.
Q2. Take the differential dVbe/dT and solve for equivalence with 1.8 mV (noting that the Boltzmann constant is m^2 kg S^-2 K-1). 1.23E9
Q3. Solve for Ln(3) * Gain = 20.89. Gain ~19.
The theory is simple but I assure you that if you have ever had to make either a discrete or integrated band gap reference then this is not so simple.
Yes! Congrats sparky4347@gmail.com !
Bingo kevin.soch@analog.com ! Congratulations!
Right answers and right reasoning lhmgma@gmail.com, big applause!
Well done ob1@aquacoustics.biz ! Thanks
Thanks david.taylor@electradx.com for your feedback! But not sure I understand your reasoning: how did you come from 21 to the gain of 7?
